You may want to move that IC a little. I think there’s an overlap with the 1n. Also, soldering that pot nearby is going to be a pain.A Spaceman Apollo 7B Layout. I still really don't like laying out ICs with more than 8 pins.. routing power nicely becomes a real pain![]()
I try my best to not have them but I haven't seen anything that says having them is bad in a simple audio circuit. I'd be more worried about running audio signal traces right next to power traces. However, I'm sure someone will correct me now that I've said something.There are a lot of vias.. is that bad?
Dang, I never even thought of that. I'll try to keep that in mind with the next one. The power is DC and the signal path is low voltage so hopefully it'll be ok!I try my best to not have them but I haven't seen anything that says having them is bad in a simple audio circuit. I'd be more worried about running audio signal traces right next to power traces. However, I'm sure someone will correct me now that I've said something.![]()
Great job. Plenty of my boards have a lot of vias, generally they aren't an issue. I do try and minimise their use as much as possible because often the layout or component position could be better and the via wasn't actually needed.This is my first shot at a PCB
A few thoughts..Any other suggestions?
What's the radius on your rounding in the corners?Basically ready for prime time; I'm just extra worryworty with this one. Oh, and I still need PCB art : P
I don't actually knowWhat's the radius on your rounding in the corners?
I think in the earlier days of DIY scene EDA, it was a badge of honor (and economic necessity) to keep a board at 2 layers, and then create a layout without adding vias at all. And while I've got that still stuck in my craw for my own layouts, I'm not going to hold it against anyone! I used vias extensively in my early boards, and there's no shame in it. Sometimes it's also required to link some islands of ground planes, if you've got them in both top and bottom.There are a lot of vias.. is that bad?
Monty layout thread is the best thread.I love that this thread is still kicking more than 3.5 years after I started it!
I'm popping in to share a build that hasn't quite worked as I hoped, with the boost and regular gain controls both above halfway, I get high-pitched oscillation.
FI don't actually knowGrid size is 25 mils here, because the total board dimensions weren't working at 50, which is normally how I like it.
If you're doing a lot of SMD work, it's a h*ckin necessity, because you've really only got two layers for the surface components, and then internal layers for supply and ground planes.
Why use smd/hybrid caps some of the time and the for the rest?
Electro caps are often lower profile as SMD, and can have their pins bent to use like like a TH. I think the weird hybrid footprint was just a CYA on my part. Don't have the same problem with film caps right now.Why use smd/hybrid caps some of the time and the for the rest?
I've noticed what seems like your earlier layouts are 1590b sized and the component fit is very tight, like on the Seabed Delay. I like these boards as they look great and are very satisfying to build. The (presumably) later boards have components spaced further away from each other. Is there an advantage to placing components further apart?For years I've avoided them like the plague, only using them as a last alternative when I'm on the brink of losing my mind.
Lately, I've started to realize how much cleaner (and less stressful) some of my layouts would have been with a few vias. Technically it's really no different than a trace that passes through the board at a through-hole component pad, and I do that many times in a layout.
I would suggest nudging the silkscreen (or the vias) slightly in cases like this. That value will probably be unreadable.
I generally route in, out and power traces to their first connections and then will do the routing of everything myself. If I don't like the way I routed it, I just delete all the traces and try again, then finally, I'll do autoroute to see what it suggests. In the end, I do a mix of auto route and self-route.I've noticed what seems like your earlier layouts are 1590b sized and the component fit is very tight, like on the Seabed Delay. I like these boards as they look great and are very satisfying to build. The (presumably) later boards have components spaced further away from each other. Is there an advantage to placing components further apart?
I was playing around with the same circuit I made before, but this time spacing things out in a 1590bb format with everything board mounted. I tried to keep power distribution separate from signal flow and make signal traces as direct as possible.
Also.. I'm smashing tf outta that auto route feature. Are there routes I should place by hand before running the program?
