DEMO Polyphemus [One Knob Overdrive]
Aleph Null
This all started with @jessenator giving me the business for using an enclosure larger than his preferred 1590B. I threatened to put a mosfet boost in a 1590XX just to spite him. That's not where I ended up, but the idea for this circuit did come to me while contemplating mosfets and revenge.
Polyphemus is a one-knob overdrive/distortion with internal voicing options that allow it to be tailored to a variety of rigs and use cases. The idea was, to do all the dialing in up front, then screw the thing shut and just rock! As it's built around a Super Hard On of sorts, it only seemed appropriate to name it after the original one-eyed monster!
The circuit consists of three gain/eq stages. The first stage is a high shelf filter that boosts everything above a set frequency by 20dB. Everything below that frequency stays at unity gain. The second stage is a simple mosfet boost, which is pushed by the first stage into clipping. The final stage is a low shelf, set at a similar frequency to the first. This flattens out the eq again. This makes for a “transparent” overdrive that emphasizes harmonics and retains clarity, since higher frequencies are saturated more and sooner. It also greatly lowers the noise floor!
Switches 1 and 2 set the capacitance/cut-off frequency in the HPF stage. Switches 3 and 4 set the capacitance/cut-off frequency in the LPF stage. HPF and LPF interact to shape the character of the gain, as well as the frequency response. Flat, transparent overdrive, various kinds of mid boost or treble boost, mid scoop, even distortion/fuzz is achievable. Heat sets the range of the Gain control. This is so that the headroom can be adjusted to suit your pickups and maximize the range of the Gain Control. Output is a volume control. With Heat dialed in, there is a moderate change in volume from the lowest to the highest Gain setting (maybe 6dB). I like to set Output so that the lowest Gain setting is about unity with bypass, but you could attenuate or boost to taste.
Here's a demo:
There's a little dedication to Jessenator on the PCB. 😘 I built mine in a 125B, as is my preference, but it'll fit into a 1590B with top mount jacks. Side jacks are possible, but you'd have to push the Gain knob up to accommodate them. And, of course, it's in green, Jessenator's preferred solder mask color.
As always, I have extra PCBs. If you're interested in building your own, just DM me.
Love the idea, the graphics, the sounds. If you did it in a 1590xx you could mount more switches on the top. I'm sold.
Love the sound and board but for naming, you could have leveraged any number of names of the original one eyed monster and kept with the SHO theme by listening to Monty Python's Isn't it Nice...
maybe I need to build this and go Monty Python themed...
The demo is bonkers lmao. Sounds really good
I was skeptical you could hold my attention for 7 minutes demoing a one knob boost, but you did it. That’s a cool range of sounds!
I felt a little silly posting a seven minute demo for a one-knob overdrive...but I demoed less than half of the voicing options, and I didn't even touch the Heat or Output controls.
I chose "Polyphemus" because it's a one-eyed monster and the name means something like "many voiced" in Greek. I am contemplating a high gain version with pre-emphasis and de-emphasis filters sandwiching a Red Llama or Fuzz Face, maybe, so there's still an opportunity to name that. I'd love to hear your suggestions!
I considered putting everything on the outside, but I couldn't think of a good way to switch the capacitors in and out without popping. Also, once Heat is dialed in, a volume knob would just kind of be a distraction.
I could see a more complicated design with resonant high pass and low pass filters. That would take more knobs, for sure! I wouldn't expect it to get bigger than a 1590BB, though.
I would love to see that!
For full on crude I suggest Trouser Snake with the volume labeled as load.
@Aleph Null what kind of rig are you using? It reminds me of the crate practice amp I had in the mid 90s. Whether that's good or bad is subjective. I'm just curious because the pedal seems like it has potential but the tone didn't sell me on it.
The pedal is feeding a Bogner Ecstacy Blue (modded Marshal) as a preamp which then feeds a Celestion Vintage 30. My usual speaker is an Eminence Big Ben, but the Vintage 30 seemed like a more neutral choice. The differences between the voicing options do sound more dramatic in the room and at volume.
