PedalPCB Radium Springs
OD is Glorious
5.00 star(s)
This is my sixtieth build... still working my way through the PPCB reverb offerings. This one has some functionality. It works - and is not too "horror-movie-crazy". The FV-1 was soldered in at PPCB and the rest was soldered by me. The pedal was a pleasure to assemble and I enjoy the result. I am a fan of traditional reverb, and this one can go beyond it a bit. it utilizes an SPDT on/off/on to switch modes and five potentiometers to dial in your preference.
I chose a white enclosure from Tayda with 15mm aluminum knobs. Switchcraft jacks and a 1kg foortswitch, The 5mm LED bezel from Stompbox is one of my new favorites for a clean low profile look - 1/4 inch hole, Using this bezel allows yu to use non-diffused bulbs. I am always thankful when one of these FV-1 pedals gets together and work. I attempt tp do the math and it is just $36 for the board and FV-1! Once you add up time and parts these are pricey pedals.
Enclosure $10
Board FV-1 and EEPROM $36
Switchcraft jacks $6
D.C. jack $1
Taiway SPDT on/off/on $2
Potentiometers $5
Knobs $10
Footswitch and breakout $4.50
This is all you got for this serial Over-Poster, GOTA? This? I'm sending you back to Troll University, man... HarryK is dropping the ball too. If ever someone needed a reality check about posting etiquette it's this guy. He is selling pedals that barely function! I feel like we need a PSA on Reverb... "If you see a pedal that looks like a poor impersonation of Xotic - run!"
OD (perfect user name, all things considered...), I'm sure you're very nice but... Just because you can post nearly every day in Build Reports doesn't mean you should. You've been here not four months and you're posting as if this is your personal blog - I'm glad you're enjoying retirement after scraping the Earth for all it's worth - to the detriment of the younger generations - but this is getting to be too much.
People can just choose not to read them of course, but when you post and post and post and post it's burying content by all of the other members who also deserve to have their reports seen. This forum is turning into a solid wall of your error-riddled reports and you're going to wear out your welcome if you don't consider the other members a little more and exercise a little restraint.
Have you met jimilee?
