SOLVED Thumb Sucker Is Unresponsive
MikeL
Maybe I'm in over my head here. I built a Thumb Sucker for my son, even though I know nothing about guitars, music or oscillating electrons... I plug it in, cycle the Big Button and no LED blinky. I have no guitar or amp to plug in so, not sure if there is any effect. Looking through previous problems, I see the LED polarity issue and I have checked that the status LED flat spot lines up with the square pad marked "k", as do the two snubber LEDs. What am I missing? Wire colors are: white is IN, black is OUT, green is -GND, red is +, blue is SW. Thanks to all who look at my silly problem and unending gratitude for a solution!
Pedals typically use center negative 9V power supplies, which is opposite to how DC power supplies intended for almost all other electronics are wired.
You can reverse the red/green wires coming from the Power I/O module temporarily to test it with the supply you have, but you'll probably want it wired correctly when you give it to your son.
