Skeptical Buffer (29 pedals EUNA)
Vild
5.00 star(s)
Definitely a good sounding soundgoodizer! (Seriously)
All the switches down and it sounds just like the original signal so I'll trust it's doing the good buffer thing in there. But once you flip the switches on it sure does liven the tone up! (Boosts the volume by a lot too)
I used the middle row for controls on the template and the board ended up so close that I could have just used pin headers to connect it the footswitch board instead so there is a little tip if you are building one.
Good looking build, Vild.
Love that name, "SOUNDGOODIZER". I'd play that up.
Some large white lettering that says "SOUNDGOODIZER" would be great! (might have to tilt it on an angle to get it all in as one word).
Then some white-tips on the switches, maybe even some white switch-washers if they exist, and large white-plastic washer on the footswitch and/or a white stomper-topper thinger... BLUE & WHITE.
