Hey I built one of those. Careful my board was backwards. The pot needed to be on the component side. Or else everything runs backwards. I still haven't fixed mine.
I've avoided using any PCBGM boards early on as I also noted their bountiful foobars. I recently went for 4 of their PCBs; the JFT Phaser, Tremolo Factory, Watch Tower and the Sabbatical Drive. All of which are yet to be fired up.Man, I still have some PCBGM boards from when the dude just got started, and nobody knew better. At least you tried yours.
Loath to even attempt them, given the horrorshows.
Ah to build, or not to build?: that is the question:Whether 'tis nobler to blindly offerSingapore-Slings and use PCBGM PCBs as outrageous kitschy drink coastersOr to make solder-fumes, creating a sea of trouble-shooting,And by opposing just bin them? Too sly, too deep,No more, and by deep, to say we sendThe heart-ache and the innumerable unnatural schlocksThat finishing them would be error, too, 'tis a confoundationDevoutly to be whizzed upon. The PCB's must die, and leepTo landfill, perchance in a stream; aye, there's a nubFor in that sling to death, what operable-circuits may comeWhen we have shuffled on to error-free PCBs worthy of our toil.
The Bard would be disappointed this isn't in iambic pentameter.Man, I still have some PCBGM boards from when the dude just got started, and nobody knew better. At least you tried yours.
(I liked it, though.)
Looks good! I prefer to use lug one as ground too, but it can be hard to get all the ground wires through the lug hole if you have multiple pickups and a ground wire from the bridge. I'd imagine factory built guitars fold lug one back and use the back of the pot because then you can prepare a bunch of pots in advance and pull them from a bin during assembly.Low hanging fruit being only 2 pots and a jack but I’m pretty proud of it. View attachment 119315
Sons P bass. Factory jack just wouldn’t hold a cord (we’ll try and steer clear of hot dog and hallway jokes). CTS pots and a pure tone jack. Someone tell me why the convention of ground wiring puts the wires soldered to the back of the pot when you can just use lug 1 of the volume pot. Yes you still have to have the lug grounded to the back of the pot but 1 wire vs trying to wrangle 3-4 seems less of a PITA. But that’s just me I guess
Or for draining spaghetti!for the DEFX PLL One
I believe the backs of the pots are grounded in order to provide some sort of balanced signal to prevent eddy currents and noise. At least that would be the theory but it's not really applicable at the low voltages of guitar pickups.Low hanging fruit being only 2 pots and a jack but I’m pretty proud of it. View attachment 119315
I don't know why they do that but I like it similar to yours. Having a short bare wire between volume lug 1 and the back of the pot is great for ground connections. The lug hole can fit that wire plus the output ground, then other grounds (pickups, bridge) fit nicely on the wire. I'd rather do that then bending lug 1 and trying to get everything together with it in a big pool of solder. Yours looks a lot neater than mine though, nice job.Someone tell me why the convention of ground wiring puts the wires soldered to the back of the pot when you can just use lug 1 of the volume pot. Yes you still have to have the lug grounded to the back of the pot but 1 wire vs trying to wrangle 3-4 seems less of a PITA.
