SOLVED First Build, getting no sound. Sandspur Fuzz
Verbzilla
Does anyone see anything wrong from the photos? Pedal switches on with no sound. Bypass signal works fine and led comes on.
I think the transistor readings are way off. What would cause this?
Transistor readings with multimeter (volts)
Q1:
E 0, B.022, C.459
Q2:
E 0, B.459, C.442
Thanks for your help, I'm sure I must have screwed something up? Haha
When you say "The circuit input is not grounding out" what did you test?
I propose you use a DMM in continuity mode to check these 2 when the effect is supposed to be on and not bypassed:
1. the IN pin on the PCB and GND
2. the OUT pin on the PCB and GND
I think you already did (1) and confirmed it is not shorted when the effect is supposed to be on, but can you also do (2)?
One time I put too much solder on the footswitch pins and it grounded and shorted them on the other side of the PCB (the part sandwiched between the switch and the PCB). This took me awhile to diagnose and desoldering that footswitch PCB is a huge pain. To test this theory you could also remove the footswitch board entirely and test wiring the effect PCB IN to the input jack directly and the PCB OUT to the output jack directly, this completely removes the entire footswitch from the debugging. I no longer put as much solder on the footswitch pins.
You might be able to shine a light through the crack of the footswitch PCB in multiple orientations and see if there are any blobs/bridges that shouldn't be there.
I do this with aligator clips and a capacitor for my audio probe
Do you mind showing me an example of a foot switch daughterboard you have soldered up? Just trying to gauge what an acceptable amount of solder on the foot switch pin is for the future. Thank you!
It is totally subjective I think, and might not be a common problem, but since I ran into it, it is just something I am now cautious of. I put in an amount that seems to make the connection and stop, but more importantly I make sure it is actually melting where I want it to be. Sometimes with surface tension or whatever, this means the hole is perfectly filled, other-times not. I do the same for toggles as well.
Totally makes sense. I will be cautious of this as well moving forward. I was trying to make them all uniform as opposed to making a connection and then stopping. Good info to know, thanks again.
build reports in the forums
edit- looking a this a little closer, check this area.. it looks like there's flux goop between your sw and gnd. electrons will try to go everywhere, they're like water in that way
  • Screenshot 2026-10-06 at 14-47-00 First Build getting no sound. Sandspur Fuzz Page 3 PedalPCB ...png
I think there is such a thing as being TOO nice when helping new builders.
I’m not saying that we should return to the dark times when I started and you needed to earn every scrap of information from more experienced builders, but sending such a simple circuit to someone else to troubleshoot is a real missed opportunity.
Hopefully, you get something out of this, but I can’t see that happening in any real way.
I think a little bit of help is ok.. plus I'm totally going to point out his failures... :ROFLMAO:
Let's just call this one a get out of jail free card..... next time he's gonna have to gruel through it and test all the spots we tell him to. Besides..... soon enough one of mine will be in this section as well and I'll be stumped. I'm still no wizard... Yet.
These threads are my favorite threads because they are a HUGE chance to get someone to level up so fast and learn so much in only a few posts. ESPECIALLY with a low component pcb with no glaring mistakes like this one. But alas, we will see what was up and learning will still happen! Stick with it though if the process has been enjoyable so far!
Yeah, the process has been a lot of fun! I never realized how satisfying it is to solder. It's honestly pretty relaxing. I've bought a handful of other pcb's that i'm going to continue on this fall/winter. I Was hoping this first one went in a different direction but I have learned a lot in the short time. Obviously I need to get an understanding of the schematic more and my troubleshooting skills only go as far as the basic stuff. I now have more of an understanding of what should have continuity and what shouldnt.
I'm very curious to find out what I screwed up on this one. It will be enlightening to have an actual answer.
Got his pcb in and I pulled all his wiring and pots off to inspect the pcb for damage… found all the pads for Q2 were in bad shape… threw in some new pots wiring and protection diode and couldn’t get it to bias… was barely getting a couple volts… Went ahead and built him out a new pcb I had on hand and will send him out a working build.. Practice makes perfect! Keep at it man… Your first wasn’t too bad.. was fairly clean for a first build.
nice, you gave him sockets... and +1 on the keep at it.
I took electronics intro in school but hadn't really physically used the knowledge in the interim years up until this summer.. And even with that starter knowledge it took me a minute to get used to doing it.. but it is like riding a bike, so there's that
Just have to remember that some components don't like being hot for more than 3 seconds.. don't rush.. anytime an iron touches the board wash the flux off before you test it .. once you get a system down it's fun.
So did you troubleshoot before or after removing the pots and wiring?
Which pad on Q2 was bad and would it have just been as simple as jumping a cooked pad vs. building am entirely new pedal?
I did try to troubleshoot it exactly how he sent it to me built.. confirmed that the bias voltage was extremely low and inconsistent.... pulled the wiring and pots and 5817 to have a closer look and found all three pads for q2 were lifted on front side of board.... rebuilt what he had and I couldn't get it to bias even after adding the couple pots and new wiring... Could I have jumpered the the pads? absolutely.. but I also already had 4 sandspur pcbs sitting here so I built out a new one... I'm encouraging him to get another pcb and try again.. or... take his build and play with it further...
Swelchy has been great. Im definitely going to keep building. Yeah, I need to be more careful about heating up components too long. I bet thats what happened with this one. Thanks for the advise everyone. I have a few pcbs I bought but I may order a couple more beginner ones for me to move onto next. I'm thinking the Modus Operandi Boost for one of them. Anyone have any other suggestions?
Smoking components etc can paradoxically come from an iron that’s not hot enough and/or not tinned properly. Footswitches are not immune (ask me how I know).
I generally dislike sockets for transistors, but they do help minimize the chances of damaging one while soldering. You might want to look into some heat sink clips as well.
As for recommendations, try to pick projects with ample room on the board so you don’t have to worry too much with soldering in tight spaces.
if you need a clean boost that is super linear, i'm going to throw in a +1 for the transcendence boost.
it's easy to build and does the thing.
if you do any opamp based boards, absolutely get the socket. makes the chip install at the end fun
How many of us finish the build.. close it up and forget to install the chip.. I know it's not just me..lol
