Glyph Fuzz
Vild
5.00 star(s)
Rips. I think I used 1n270s but I didn't trial anything else out.
Not much else needed to be said besides that I should've wiped it down for the picture haha.
Nice built ! How do you manage to bend the legs of the diodes without breaking them ? :unsure:
Not my build, but I've bent countless diode leads and never broke one. I generally use precision needle-nose pliers. I use them to grip the lead right next to the diode body, then just bend the lead down. This puts all the torque on only the lead wire, there should be practically zero stress on the diode body itself.
Even better than the small needle-nose pliers are needle nose pliers with round (technically, conical) parts. My wife has a set from her jewelry-making days. It allows the wire to be bent with a deliberate, rounded radius (as opposed to a hard angle, as I get with the pliers). Maybe it's just laziness, but I generally don't use those for pedal builds, the simple bends feel adequate. But for my amp builds, I do take the time to use the "deliberate radius" pliers.
Back when I had a 3d printer I printed this component bender thing. It's to help get the right length but I figure it also helps spread the pressure by giving it a decent surface to sit on so I use it with germaniums. Otherwise I normally get better results bending by hand anyway.
Round-nose pliers rock, like these. Very easy to use, doesn't strain the wire as much as flat -amazon link
