PedalPCB Scenario (Gladio SC) - Build + Troubleshooting?
kekdoso
5.00 star(s)
I finished my Scenario Preamp build a while ago and have been putting it through its paces since.
This was my first build using a PedalPCB project, although I've previously built a few Musikding kits. It was a fun experience and a nice step into the PedalPCB world. The PCB design is really nice, although I found that some areas required a bit more finesse during assembly to avoid accidentally shorting components.
One thing that makes this pedal particularly special to me is the enclosure. I asked my dad to take care of the painting as a birthday present, so there's a personal touch to this build that makes it much more meaningful. It's not a professional finish by any means, but that's part of its charm. It's something I really want to keep on my board and, most definitely, a pedal I'll hold dear.
Regarding the sound, I never actually got to play the pedal this circuit is based on, the Gladio SC. However, judging from the many sound demos I've heard online, I was expecting this one to be a bit more transparent and defined, especially considering how often it's praised for its SRV-style tones.
I can only seem to get close to that territory when I crank the tone to around 3/4 o'clock and compensate using the clean blend. I'm not entirely sold on the sound just yet, although I can't say it sounds bad or that it doesn't sound and feel like the Gladio, since I've never had the chance to try the original.
I also experimented with the internal trimpot, but all I seem to get out of it is an increase in OD/gain on the bass side, whereas I was expecting it to behave more like an EQ. Maybe I'm missing something, or perhaps there's something worth troubleshooting here? It just seems to be muddy and "sucking tone" when it's on.
As for the PCB and the build itself, I really can't complain. Everything went together nicely. My only regret is not getting the 3PDT breakout board!
Overall, a very enjoyable build and a particularly special addition to my pedalboard.
Welcome! I started the way you did but with Stewmac kits. I think they use some PPCB layouts or boards like their Tremolo is the same board as the PPCB Woodpecker. But I digress...
I love the artwork and what a great gift it is to have your father put so much effort and creativity into the design.
Regarding the circuit's inability to get transparent, I cannot speak to that, but if you post clear pictures of your board in the trouble shooting section of this forum another member may be able to help you determine if there is a problem.
You can also use the the search bar here to type in this circuit's name and see if others have made a build report, that way you can compare your components visually and you can also read their opinion of the circuit. Meanwhile I will zoom in on your board and see if I can see anything.
Edit: I just checked all of your values against the BOM and they look good, but what about the op amps? I cannot zoom in on them? Where did you purchase them?
Thanks, OD!
Yeah, I'd love to get some Stewmac stuff, but Musikding is much more attainable here in Europe, especially when you factor in customs and shipping costs.
I've reviewed the wiring and component values multiple times by now, but I really can't seem to find anything wrong. At this point, I've even started considering experimenting with capacitor values in the input-stage EQ circuit, since the pedal sounds REALLY dark and muddy when the tone control is set anywhere before 1/2 o'clock (especially in the 9 o'clock range).
I sourced all my components from Musikding, including the op-amps. 3 TL072 on the bottom (IC 1,4) and top right (IC3) and 1 RC4558 (IC2) on the top left. I must admit I hadn't really considered the op-amps as a potential issue, mainly because the pedal doesn't sound bad per se. It just sounds... meh compared to what I was expecting.
Thanks, OD!
In that case there may be a way to mod the circuit. I do see several builders have made a report, you might message one of them or read through these build reports.
One
Two
Three
Four
Five
Six
Thanks, OD!
just took mine for a Test drive, it can sound Dark if the toggle is in the Up position!.
I like the Bass trimmer at 10.00 O'clock if 7 is fully CCW.
The Tone is between 2 & 3 O'clock if 5 is fully CW
That is with a Tele on Neck pickup & Fender Deluxe based Amp Head.
It is definately in the Transparent category to my Ears!
I agree it has a lot of opamps for what it does!
I would say it is limited if you have a Dark sounding Amp.
You could try increasing the Tone pot to B10K or reduce C8 - 68nf going to Ground with 39nf or 47nf
I built one of these a while back but I don't remember it sounding bad. I have another coming up. I'll let you know if it sounds the way your describe yours
I built one semi-recently, though it was a commissioned build, so I didn't spend a ton of time with it. However, I do recall it was fairly balanced, tonally; I definitely don't recall it being overly dark. And the person for whom I made it was really happy, I'm pretty sure he would have complained if he thought it wasn't built correctly.
I know everyone says "check your component values", and I hate to repeat that, but... I'll humble myself and link to my very first PPCB build, which had issues. I checked - doubly and triply so - the component values. My main mistake was actually mis-reading the BOM; I mis-read a 150p cap as 150n, which caused a massive difference in volume and tonality. I was only off by 1000. ;)
In the Scenario, C7 and C9 are 100pF filter caps in the RC4558's feedback loops. If you made the same mistake as me, and accidentally used e.g. 100nF, then I would indeed expect the pedal to be overly dark. C2/1uF and C3/33nF are two more opportunities to make the circuit overly bass-heavy.
Another area where there's risk of killing too much high-end is in the tone control sub-circuit: that's the B5k tone pot, R8/1k5, and C8/68nF. Triple-check all those for correctness. Also, if you accidentally used a log- or audio-taper pot for the tone control (i.e. A5k instead of B5k), that would definitely cause it to have an unnatural sweep; and if I'm thinking this through correctly, it might cause the exact problem you're describing.
Link to build doc with schematic.
