Pauleo1214
Don't you love when your combo build works the first time, 75% of the time?
I am currently on a hot mess streak. My last four pcbs (of which I built successfully before) produce dry signal but no modulation.
I decided to focus on another weird build, four HAARPs in parallel. A QUAARP if you will. Except one of them doesn't produce any modulation. The PCB in question is the one on the upper left (component side up), upper right (pot side up).
So far i checked all my resistors, reflowed all my solder joints, checked that the ICs are getting proper voltage (they are), swapped the regulator and tl072's, and swapped one of the EEPROMs. No dice. Could anyone who is an eagle eye with resistor color bands see if I possibly subbed a wrong value? My next guess besides that is a broken trace.
