Locrian99
Got the pedal all together ready to test it out.
LED doesn’t work…. Huh that’s weird. Wait I’m not getting any signal either wtf. Check some voltages everything looks good. LEDs is getting power. Check continuity with ground. Nothing weird. Check switch that’s good, switch seems fine. Check continuity between led ground and the sw pad nothing wtf.
In case anyone was curious you need to solder all the pads on your header. Not just the one to hold it in place.
