1/4W Resistor in 1/8W size?
falco_femoralis
I did the same thing a few months ago. I didn’t realize that 1/4 W resistors came in that smaller size. I don’t recall which brand they were, but I will be checking the size for sure going forward.
Yes, I've bought some as well. They're fine, and even very useful when you have to parallel two resistors to make a resistance value you don't have. I will note that very few of our circuits in normal operation generate enough current to get these resistors even close to 1/4 watt. So while they may look odd next to larger 1/4W resistors, they work just fine.
Note added: P = V^2/R. Hence, even if you put the full 9 volts across the resistor (which we rarely do), it has to be ≤324 ohms for the power to be ≥¼ watt.
Using the parametric search function on DigiKey or Mouser, I always look for highest wattage in 1/8W size. All the common E6/E12 values, and even some wacky values, I can generally find in 1/3, 0.4, or even 1/2 watt rating. I think I’ve even snagged a few 0.6W resistors in the smaller size. Not needed, but I love me some overkill.
And I did it a few years ago with a major (for me) restocking order; I got the wrong series of 1/4 watt from Mouser (my mistake) IMG_0866.jpeg and they were half watt sized. I got very good at standing them up in alternating directions to make them work on boards.
as small as an 1/8W resistor. Is this weird?
Happened to me once. Wasn't paying attention to the matrix of data. Nice for if you're overly concerned about ratings but want to build with 1/8W footprints. I think I used most of them up in verification builds, but it's not the worst. I know from an a e s t h e t i c perspective it's not desirable, but they get the job done.
