1/4W Resistor in 1/8W size?
falco_femoralis
I just ordered some of these in 820R, 1K, and 10K, and selected 1/4W thru the filters, and they are as small as an 1/8W resistor. Is this weird?
The description for these lists 1/4W and it matches up with my invoice. Just trying to find out if I have to look out for this in the future with other brands etc etc
yeah gotta check those datasheets.
a while ago i ordered some 1W resistors for an amp build and they ended up being 1/4W size. wasn't stoked about it but eh, it happens.
I did the same thing a few months ago. I didn’t realize that 1/4 W resistors came in that smaller size. I don’t recall which brand they were, but I will be checking the size for sure going forward.
Yes, I've bought some as well. They're fine, and even very useful when you have to parallel two resistors to make a resistance value you don't have. I will note that very few of our circuits in normal operation generate enough current to get these resistors even close to 1/4 watt. So while they may look odd next to larger 1/4W resistors, they work just fine.
Note added: P = V^2/R. Hence, even if you put the full 9 volts across the resistor (which we rarely do), it has to be ≤324 ohms for the power to be ≥¼ watt.
Using the parametric search function on DigiKey or Mouser, I always look for highest wattage in 1/8W size. All the common E6/E12 values, and even some wacky values, I can generally find in 1/3, 0.4, or even 1/2 watt rating. I think I’ve even snagged a few 0.6W resistors in the smaller size. Not needed, but I love me some overkill.
And I did it a few years ago with a major (for me) restocking order; I got the wrong series of 1/4 watt from Mouser (my mistake) IMG_0866.jpeg and they were half watt sized. I got very good at standing them up in alternating directions to make them work on boards.
Happened to me once. Wasn't paying attention to the matrix of data. Nice for if you're overly concerned about ratings but want to build with 1/8W footprints. I think I used most of them up in verification builds, but it's not the worst. I know from an a e s t h e t i c perspective it's not desirable, but they get the job done.
Those hot dogs give me mad agita
Well, I learned a new word this morning😉
But, my apologies. Images are important. I’ve just decided I’m going to make waffles for breakfast. I’ll try to remember to post a trigger warning before posting any gut shots. Hopefully, you can imagine a hot buttermilk pecan waffle sitting on a plate, with melted butter, and enough maple syrup to get into each hole. That should calm your agita. Sorry.
I appreciate your description, but can you tell me to imagine homestyle waffles instead? I'm not so fond of pecan, but I will take it if there's no other option
