DeadAirMD
I'm building a 3-in-1 pedal with the Muroidea, General TSO, and Closed Circuit pcbs. I'm planning on using the charge pump pcbs to make all of these effects 18v.
My question is, do I need to change the values of the components I'm using to make this all work? Do all of my caps need to be 25v or higher? If I'm running these all off of one DC jack, do all of the voltages add up for the caps values? I also want to have a foot switch for each effect, do I need 3 charge pump pcbs, or can I use one and connect it to the two other 3pdt switch pcbs? Do you have any other suggestions on how to make this work the best?
Thank you for any information you provide and have a wonderful day.
