2.54mm Pin Headers for SIP Sockets
DeadAirMD
Anybody know where to find pin headers with 2.54mm spacing and .8mm circumference?
Looking for something that fits sip sockets. Tired of soldering clipped off resistor legs. The 2.0mm Tayda pin header's pin will fit into the socket, but the spacing doesn't allow more than one socket. I really don't want to individually cut and solder individual headers.
@Nostradoomus
This........
Into this.......
Or into this........
Into this.......
Every 2.45mm male pin header I've found has pins that are too big for the SIP sockets I have. I found out that the 2.0mm male pin headers have a pin head circumference of .8mm (datasheet), do fit. Just trying to find 2.54mm male headers with .8mm pin head circumference. Not too crazy
What about these? Cut out the middle man.
@Robert the datasheet looks like the pin heads should fit into the sip sockets. Just want to have the ability to easily insert smd components into a pcb while also being able to easily remove them to use for other projects/component "rolling".
