I recently build an OCD and Rat in 1 enclosure with an order switcher, and everything is working as it should. However, the output seems rather low. Where a normal ocd would be at 12 o’clock, mine has to be pushed to almost 4 to reach the same volume, and some of the high end that’s in the original isn’t there in the clone.
I’m wondering if there I need higher voltage caps since I’m running 2 pedals off of one dc jack, or if changing the pots will affect the headroom? Or is it just the different components won’t make them match?
thanks in advance!
thanks in advance!
