24v for sanguine distortion and Tyrian distortion?
ErickPulido
I was wondering if anyone has tried it: using 24V on this pedals, I know the caps must be higher voltage, is there a downside?
I don't see any reason to change the potentiometers. Increasing the power supply voltage increases the headroom. The sound will change because there will be less distortion from opamp saturation. You will also be able to overdrive your amplifier even harder.
Thank you so much
