2P3T Rotary Switch symbol/footprint
I think that the madbean 2P4T ( _MB_switches:2P4T.MINI ) is awfully close, though you might have to goof around a bit with the pin mappings. The middle pin is 3mm from center instead of 2.65mm, and you might want to increase the pin size a touch, they're ~1.1mm instead of 1.2mm. (And the madbean footprint has two center pins instead of one, but that's probably fine).
I think there's a link to the madbean footprints here: https://forum.pedalpcb.com/threads/eagle-kicad-footprint-equivalents.15853/#post-273941 . I use the potentiometer and switch library all the time.
In terms of the pinout/mappings, your guess is as good as mine with what maps to what. You might need to have one in hand and measure with a multimeter which pins switch with the others.
I hate when I do this. I already had the madbean library...i forgot to install it. Guess I'll throw a couple of bucks at Robert and grab a switch and some other weird parts.
