matmonster58
A friend of mine has asked for a 4 band preamp for his bass. I've built a good number of pedals, but really haven't designed much myself. I'm taking on the project as a learning experience and will be documenting my progress here, mostly as just a log for myself but also to get feedback from the community. I am mostly looking to learn how to use Kicad and design pcbs.
Here is my preliminary design (pdf attached for better clarity). LTspice is what I use for school so it's what I'm using for my mockups
I designed the input stage after the EQD Arrows boost. It's not really a true buffer, but I like the sound of that circuit so I figured I'd put it at the beginning of my circuit. The EQ stage is taken from the preamp of a GK 800rb amp. I started with the EQ from that amp then tweaked components until I got a response I liked.
This is not a flat preamp, it has a bit of a 'preshape' that I think will sound nice. It also has a slight volume boost which I don't mind either. I could make a more neutral preamp, but I want to make something interesting that you can't buy off the shelf.
The eq bands result in +-10db at 30hz (very low but acting more as a low shelf) , 450hz, 1100hz, 10k+-ish (again more of a high shelf).
Since it is going to be an onbaord preamp, small size is a priority. Everything is going to be done SMD
If any one has feedback on things I could improve, components I could simplify or remove, or anything else, I'd love to heard it.
