42TL218RC Audio Transformer question
Assuming I plug it like in the neurocyton or british royalty. Is there an attenuation (I guess there is) in voltage swing between the primary and the secondary? I would like to put it between 2 gain stages with preamp tubes like 12AX7 in a clean channel to try...
so approx 3db of loss in the 300-3400 Hz range ? OK, it's fine...
Thank you
