9mm Pots
dpsnacks
I bought a bunch of 9mm pots like a bozo. (50 A100k, 20 B100k, 15 A1m and a smattering of others.) I assume all the connections and drill templates are gonna be slightly off as a result of the smaller size. Is there any good use for these or should I just reorder everything 16mm?
@dpsnacks
Those 9mm are INCREDIBLY USEFUL!
Ex:
Need to mod a pedal and add a presence control to take away some shrill high-end overtones, but have limited space between the Gain & Vol where another 16mm pot won’t fit — 9mm pot fits with Davies-style 1900 knobs on top.
Add a bass control-mod to the Nobles OD… — 9mm.
Want to add a pre-gain control to a fuzz — 9mm.
Need to flatten out a Muff’s scooped tone-stack — 9mm.
Run out of space on your pedalboard for a Klon/Rat/Muff/TS808/Muff/Guv’nor/chorus/verb/phaser/boost… etc, but could squeeze a 1590A build on the board — 9mm pots.
I once bought the wrong voltage-size caps and some incorrect jacks — I tried to give them to a friend/mentor who repairs amps — “when would I ever use these?” said I — “Keep them” he insisted.
He was right. They eventually proved useful, I needed them.
If you’re convinced you’ve no use for them, I’ll buy them from you. I’ve got some 1590A builds pending and can’t leave well enough alone and mod things I shouldn’t.
PS: take a countersink drillbit and shave 0.5mm to 1mm around the potholes to gain back some thread purchase.
I just bought a large assortment for my breadboard "Pot Holder"
@dpsnacks
Well, here's the thing: I'm not convinced. I bought 10 PCBs and then bought 10 more PCBs, and then did a huge order of the parts that I think belong on all 20 PCBs (with no experience)... and I won't have space in my office to actually sort these parts out and build something for probably 3-4 months. I may have the wrong caps and other issues also, that I won't find out about for weeks LOL
If I could bother you with it I'd love to, I guess send photos of what I got? And if you could let me know if I got the right kinds of shit, that would be much appreciated. 90% of the PCBs came from here. I know some kinds of caps are better at some values and some uses than others... I think...
edit: Now that I think about it I may also like to commission a 1590a build from ya...
Some projects are built for 9mm, from a variety of project suppliers.
Couple examples:
cowgirl0-jpeg.4199832
Madbean 1590G Wigl board in a 1590B enclosure because top-jacks — 9mm pots.
filigree1-jpg.4183263
BYOC 1590A Rat build; 9mm pots with enough space left over to add two mod switches.
Those are just my last two builds with 9mm; some boosts and other things before that … Oh! And I had a 9mm dual-gang in my PPCB Shallow Water for a red hot minute before changing it out for a 16mm DG non-PCB mount I cobbled some legs onto. Should’ve stuck with the 9mm, whatever — I’m ordering the correct part for that one soon.
9mm, Ah lurves dem tings.
  • Love
Reactions: fig
I know that Madbean uses 9mm in some projects. He also sells a little adapter to use wire to hook them up to the PCB (could also do it with Vero you have any). Check under Breadbuddies: https://www.madbeanpedals.com/projects/index.html
I've noticed Brian uses them for some applications, but not all. I wonder if that's because of the 0.05W power rating on the linear taper ones.
Maybe that makes them under=speced for a volume knob? (I don't know.) But I noticed PedalPCB doesn't use them either, so I'm guessing that's the main reason.
  • Like
Reactions: fig
