This is called. say it with me…..
“confirmation bias“
wait someone trashed Neil?
I'm not white-trash, just ... slight-trash.
Yes of course, but is was an obvious and easy thing to check. The signal on one end of C12 was fine but on the other it went bad. No change.This is called. say it with me…..
“confirmation bias“
You should try swapping C6 to a 100u cap. 470 is pretty high for a bypass cap and 100u is much more common. It's also from a different batch of caps. You could run a 100n in parallel with this if you want, but it's not necessary if you power supply is a nice Voodoo labs or similarYes of course, but is was an obvious and easy thing to check. The signal on one end of C12 was fine but on the other it went bad. No change.
ChatGPT then wanted to look at the voltage section and zeroed in on C6, the 470u cap. It suggested changing it out which did not work. Then it suggested tying a .1 film cap to VREF as close to IC1 as possible then to ground. This removed the buzzing. I probably have a bad batch of 470u caps.
Thanks.You should try swapping C6 to a 100u cap. 470 is pretty high for a bypass cap and 100u is much more common. It's also from a different batch of caps. You could run a 100n in parallel with this if you want, but it's not necessary if you power supply is a nice Voodoo labs or similar
Also try C2 to a 100u if you still have buzzing
It's worst with a guitar. A test tone isn't too bad.Are you using a test tone? With this being a filter network, not all frequencies will pass through C12 anyway.
You could pull c12 and the circuit should still pass audio.
I'll give the 100u a try. The buzzing stopped with the .1 cap from pin 3 to ground. I'm not thrilled with the sound so making some changes can't hurt. Just a note, chatgpt kept referring to VREF all along and once I asked the right question it finally sent me to C6 and a solution to try.You should try swapping C6 to a 100u cap. 470 is pretty high for a bypass cap and 100u is much more common. It's also from a different batch of caps. You could run a 100n in parallel with this if you want, but it's not necessary if you power supply is a nice Voodoo labs or similar
