junderwood
Taking a freshly built Cheesemonger fuzz pedal out for a spin in a mix to see how it works. So far I like it, but it does have a bit of a low output issue I think. Anybody mod these to address that? I'm pretty sure I got all the components right ...
I'm slowly getting a little better at bonking letters/numbers into the aluminum cases. This is my favorite aesthetic - I love the rough and ready industrial vibe (which I totally swear I was doing before I knew Fairfield was doing it ). A trick that's helped me is to use a rubber or felt pad underneath little block of steel I use as an anvil on the other side. Something about increasing the contact time by absorbing some of the shock of the hammer blow makes a better indentation. I also recently purchased an arbor press to try to get much better/accurate impressions but I haven't been able to get enough torque on it yet. Would also be really curious how other people do this if anyone has found success in getting accurate and repeatable punching.
In order to clear the interior of the led mount I had to solder the pots way up on their tippytoes, but it all worked out perfectly. I absolutely love building PedalPCB projects - they're always super well laid out and well made.
Here's the link to the in-mix test (An especially *cheesy* partial cover of Wolfmother's already cheesy 'Woman'):
Settings in-song are as you see them in the photo. Pedal is in full cheese mode.
Signal chain: Guitar (Kiesel Leia w/ Lollar alnico pole p90s) > Bogner Harlow V1 > Tayda EP Booster clone > PedalPCB Cheesemonger > Kemper
Guitars amateurishly double-tracked w/ Tone Junkie 'Super Dark Magic' and 'Spanky' profiles. Created with Reason 12
