A multimeter that can read frequencies over 50hz
_aj666
So I finally got my flintlock flanger up and running and would like to start calibrating, but it seems like my multimeter doesn't exceed 50hz without overloading and not showing anything. Is there a particular DMM you're using that you could recommend for this?
I bought the Proster vc97 for the Flintlock. I checked Amazon, they don't have that model anymore but they have others. Just verify the frequency specs, here are the specs from the VC97: 100Hz/1kHz/10kHz/100kHz/1MHz/30MHz, +/- (0.5%+4).
I had the same issue too. I tuned it by ear. It sounds great, but it does make me wonder if it would sound greater if properly tuned….
I was told that the Fluke has a model that will measure the frequency.
I bought a cheap Aneng M108. It helped me calibrate my flintlock so far. Hasn’t helped me figure out the audio issues…
My Fluke 179 is rated to 100kHz. Works great for audio, and I have a dedicated Fluke frequency meter if I need to go higher.
