SOLVED Acrobat not working leds blinking.
PAGOON
I just finished building the acrobat and I plugged it in and the leds started to blink when I tried to use the pedal. No sounds shirts out the power supply … I think it might be the input and output jacks I asked about a while back… but I may have mixed up the switching and non switching ones in the bag I have .. so I need to figure out how to tell which ones are swiping and non switching of that’s the issue… a-1122 i believe was the correct part number. Right?
Nothing is jumping out at me from your pictures, but the LEDs are blinking usually indicates that your power supply is having trouble starting up because the pedal is trying to pull more current than it can provide. This usually means a short somewhere in the power rail.
