ADHD v2 Fulltone OCD clone
TillMack
Build Rating
5.00 star(s)
Hey folks,
thought about some all-time classic Overdrive pedals and OCD full tone came in my mind.
I ordered the pcb and the other parts.
Made a huge mistakes for my UV template. I used the same fonts like Fulltone and tried the "balloon" font to write ADHD.
First I try OCD to look if it's the font I need.
I saved booth file and uploaded the wrong file on Tayda. Thats a bit odd for me. But it is what it is.
This pedal is real fire !
I tried it and it turned out, that this will be one of my favorite pedals ever!
I really recommend the ADHD if you are in search of a real gem overdrive pedal.
First I thought: "hmm, sounds okay" but then I turned the drive up and was blown away.
Made the LP/HP switch a bit too off, should be +1mm on the x and y axis, then it's easier to get everything in.
But the good thing is, I don't had to off wiring something.
As always, PedalPCB design is flawless and easy to solder.
Very nice! I've got two I am having to redo because the control labels were backwards. As they say, sh!t happens, lol. Realized after boxing up....anyway, glad you are digging how it sounds. I couldn't decide on a version but pulled the trigger on this one. I am awaiting a 3-hole tayda enclosure that I plan on making mine fitting in. I haven't done the graphic, yet. Would you mind sharing what font that is?
