RICHB555
Would appreciate help with this morning’s attempt- the Aion Andromeda Deluxe (Nordland ODR-C). No signal when engaged except very faint what sounds like the working pedal but barely audible. Passes signal in bypass. LED is lit when pedal engaged. Green 3mm LED diodes in D4 & D5 light when strumming guitar. Reflowed all joints. Checked for continuity on off board wiring connections. Reseated and replaced with other 4558 ICs. Checked pinouts are correct on 5088s and 5457.
IC1
Pin 1 1.44
Pin 2 1.42
Pin 3 0.81
Pin 4 0
Pin 5 1.09
Pin 6 1.27
Pin 7 1.42
Pin 8 9.54
1C2
Pin 1 1.45
Pin 2 1.45
Pin 3 1.42
Pin 4 0
Pin 5 0.81
Pin 6 1.44
Pin 7 1.44
Pin 8 9.54
Q1 5457
D 9.53
S 0.96
G 0
Q2 5088
E .24
B 0.78
C 9.53
Q3 5088
E .28
B .79
C 9.53
IC1
Pin 1 1.44
Pin 2 1.42
Pin 3 0.81
Pin 4 0
Pin 5 1.09
Pin 6 1.27
Pin 7 1.42
Pin 8 9.54
1C2
Pin 1 1.45
Pin 2 1.45
Pin 3 1.42
Pin 4 0
Pin 5 0.81
Pin 6 1.44
Pin 7 1.44
Pin 8 9.54
Q1 5457
D 9.53
S 0.96
G 0
Q2 5088
E .24
B 0.78
C 9.53
Q3 5088
E .28
B .79
C 9.53
