Hi All,
I just finished building the Aion Elysium (Ibanez EM5 Echomachine clone) and have an issue with the pedal having some thumping noise which starts to self oscillate with feedback turned up. This happens even with guitar not plugged in which means the noise gets generated someplace in the circuit. I checked it on a power adapter and through battery power with same result. I went through all basic checks on part values, alignment, cap & diode polarity etc and don't see anything wrong. Only thing that comes to mind is the L7805 regulator - is it possible this creates noise which gets amplified through the delay chip? Noise rate follows pot settings - level makes it louder, delay controls the speed of the thumping, feedback makes it oscillate.
Pedal itself works when I plug in the guitar - all pots work correctly, I can adjust the internal trim pots etc however with the current issue present it's unplayable. I used standard 78L05 regulator, looking through BOM it refers to Mouser for LM78L05 (926-LM78L05ACZ/LFT7 mouser code) - is that something worth getting and replacing?
Aion BOM for this build >> https://docs.google.com/spreadsheets/d/18f6kvSrgOrAysngqES_IV0DSfYO0Tc3MUngthaZUwHU/edit?usp=sharing
Aion build docs with schematic diagram >> https://aionfx.com/app/files/docs/elysium_documentation.pdf
Thanks in advance for your help!
