Hi, sorry for spamming up your thread. I just noticed an issue with the drill template I sent in my first reply.
I hadn't taken the screw posts into consideration and just copied the hole locations from Aion's template, so now my In and Out jacks will not fit.
I'd recommend moving the rear jack holes a little closer together.
That's my current plan. Between making the hole slightly larger (horizontally), filing away at the aluminum (but not too much to interfere with the screw post) and shaving down the side of the box jack I think I can make it fit.Can you get a box jack to fit there?
Sorry for yet another double-post. I found even more issues with the rear jack hole locations in the drill template I posted, so I'd recommend not using them.
