Synchrony Pedalworks
This is a great pedal. It sounds fabulous. I really like that you can have two different speeds for the LFOs. That ability makes for some unique and musical sounds. The build is complex, but doable for those that have done a fair share of builds. I opted out for the added jacks and kept it as simple as possible. In hindsight, I would also leave out the true bypass switch, because I use a switcher and do not require true bypass. Also, I would leave out the LFO cancel switch.
The enclosure is a B-stock from @StompBoxParts. You will have a hard time determining that it is a B-Stock. It is absolutely gorgeous. @amplifyfun also did the UV prints and the work is impeccable.
If you are a phaser fan, you need to make this pedal!
