eh là bas ma
Hello,
I am having a hard time debugging this circuit, although it should be quite simple, I hope.
I am building the Sunn Beta Lead/Bass preamp. I'd like to have both versions on one board, so I opted to add two extra 4PDT toggleswitches to be able to change 7 values in the circuit.
Musikding sent me one of the old boards, so I did the "version 1.0 C-MOS fix" as instructed.
The only issue I have is that the Treble pot is acting strangely in the last few bits of the last quarter of rotation. It's happening in a narrow spot, just before being set fully CW. There is a slight increase of volume, just before the signal fades and is covered by white noises. In other words, all controls are ok except the treble control when it's set fully CW. Almost the whole rotation is fine, and the pot does what it's supposed to do.
Both Lead/Bass toggleswitches sound like everything is working fine. However I had a doubt about how to wire R23 to the toggleswitch : one side is grounded, so i am not really sure if my wiring is allright.
For every components on the toggles, I found the pad with the incoming signal, wired a blue wire going to the middle 4PDT terminal. Then, both Lead and Bass components soldered at the outer terminals, with their remaining led connected with a wire soldered to the output pad. For R23 it's the grounded pad, I hope it's correct ? I tried to invert both wires for R23, and didn't notice any change.
I wonder what could cause the Treble pot to go off the rails in the final part of its rotation ?
What's happening, according to the schematics, when the Treble is set fully CW ?
Every help and every suggestions are welcome !
Edit : just found out that a famous builder has a similar issue on his build (v1.1) :
Aion Beta Bass preamp
The beta preamp can be built for either guitar or bass with only a few component changes, this one being the latter. I've been playing it unboxed for a few weeks and finally came to the conclusion that it needs to go on my board. I actually kind of avoided this project for a while because I...
forum.pedalpcb.com
