eh là bas ma
Hello,
I wonder if there is some issue with my Xenotron build, because it doesn't always fit the descriptions from the original manual and from Aion's instructions.
I have extra doubts about the Manual control : i can probably achieve some sort of chorusing and flanging effects, but i can't hear any phasing effect.
The modulation is most audible when Manual is fully CW, and it's more and more subtle as i turn it CCW.
Fully CCW, nothing but clean signal. I can get a faint modulation if i turn the Feedback fully CW, and if the BBD trimmer is set in a narrow aera of its rotation, where distortion can easily appear depending on the other settings.
Led 4 on the BBD daughterboard is a transparent green led, from musikding. That's the only one pulsating when Time is engaged. Led 2 and 3 are also lit, but steady.
When Space is engaged led3 stays steadily lit and led 1 and 2 are pulsating.
Looking at led 4 while turning Manual, the led goes from fully bright to fully turned off when Manual is fully CW. Turning CCW, the lowest point is brighter and brighter, until it only slightly pulses when fully CCW. Led 4 is always brightly lighting up at the highest point of the pulsation.
On my build, it's kind of hard to find a position on the BBD trimmer where i can have a modulation both quiet (no ticking, no distortion) and as effective as possible. It sounds like i have to sacrifice either a clean modulation, or the most audible and noticeable effect.
If i try to get rid of every distorting noise, i need to reduce the modulation strength. Instructions mention 11'. That the aera where the BBD is starting to work on my build, at 11' the modulation isn't clean at every settings. Around 2' the effect is more effective on the signal, but it saturates also more easily at some settings.
Here is a sound sample with the controls settings described in the comments :
The controls are : Manual fully CW, Depth fully CW, Rate and Reaction (Feedback) around 12', Action (Mix) fully CW, Input Level fully CW. BBD Trimmer between 11' and 12'.
During the recording, i turn the trimmer to 2', after that, Manual is turned fully CCW, i turn up the feedback when Manual is fully CCW. Then i turn Manual back to fully CW.
I am a bit confused because, according to the original Lovetone manual and Aions instructions, it should be phasing with Manual going CCW, but they also say that there could be some dead aera at each ends of the Manual pot rotation...
"Manual
Determines the off-set value of the delay time. This gives
the default steady setting for delay time (when the Depth
is at zero). Short delay times (anticlockwise settings) will
give phasing. Short to medium delay times will give flanging
(with regen.). Medium to long delay times will give chorusing
and double tracking" (...)
"the noise factor very much depends
on the context of use. Indeed on many occasions it actually
adds interesting rhythmic and atmospheric articulation.
Some “dead” area at each extreme of this control is normal
and provides extra offset or “swing” for the CV/Pedal input.
Around these regions modulation depth will appear to be
reduced (or even non-existent) "
Does your Xenotron also behave like mine ?
Is it ok that Manual affects the modulation this way ? Less and less modulation going CCW ?
Should i look for some issue on my build ?
Every observations and suggestions are welcome !
"Manual
