MichaelW
Hey guys,
I just finished building an Angry Andy and not sure if the boost is working correctly.
In non-boost mode, everything works fine.
In Boost mode, it works as its supposed to when the gain knob is 12 o'clock or less.
But if I turn the gain up any higher it starts squealing like a stuck pig. Not "good" feedback mind you, but uncontrollable squealing when there's no note being played. If I play through the squeal it works but as soon as I mute the strings its starts squealing.
If I put my finger on the boost stompswitch the squealing stops. I'm wondering if there's a ground issue?
But then why would it work fine when the gain is dialed back to noon? I searched and found a couple of old threads describing the same issue with no apparent resolution. Does this pedal just really need a noise gate after it at the highest gain settings?
Thanks in advance!
M-
Thanks in advance!
M-
