My issue seems similar to many others posted here but following their troubleshooting hasn't gotten me working. I built three at the same time and none are working. My V3207/V3102 came from eBay and might be bad but I didn't expect 3 out of 3 to be bad. Pics attached might help.
All units' Rate LEDs flash along with the Rate knob adjustment.
All units pass clean signal in bypass.
All units pass clean signal when engaged andcut out volume reduces when Blend turned all the way up (e.g., no wet signal coming from the circuit).
Voltages are listed below. I've highlighted the voltages that seem out of spec based on other past posts.
TL022CP https://www.taydaelectronics.com/tl022cp-tl022-operational-amplifier-ic.html
RC4558P https://guitarpedalparts.com/products/rc4558p-dual-op-amp
Trimpots all worked to adjust the above voltages.
V3207 https://www.ebay.com/ipp/253750581429?transactionId=2932391995015&_trksid=p2047675.l48352
V3102 https://www.ebay.com/ipp/253750581429?transactionId=2932391995015&_trksid=p2047675.l48352
* Depth turned down and Rate turned up
I need to do some more work on Unit 2's R24. Does anyone have any idea where to look next? I do have more V3207/V3102 pairs from the same seller I can try. Or I can order some from a different vendor.
| IC1 | Unit 1 | Unit 2 | Unit 3 |
| 1 | 4.8 | 4.4 | 4.3 |
| 2 | 4.4 | 4.4 | 4.4 |
| 3 | 5 | 4.4 | 4.3 |
| 4 | 0 | 0 | 0 |
| 5 | 4.4 | 4.4 | 4.3 |
| 6 | 4.4 | 4.4 | 4.4 |
| 7 | 4.6 | 4.4 | 4.3 |
| 8 | 8.8 | 8.8 | 8.8 |
| IC2 | Unit 1 | Unit 2 | Unit 3 |
| 1 | 5.2 | 5.1 | 4.6 |
| 2 | 5.2 | 5.1 | 4.6 |
| 3 | 5.2 | 5.1 | 4.6 |
| 4 | 0 | 0 | 0 |
| 5 | 5.2 | 5.1 | 4.6 |
| 6 | 5.2 | 5.1 | 4.6 |
| 7 | 5.2 | 5.1 | 4.6 |
| 8 | 9.2 | 9.2 | 9.2 |
| IC3 | Unit 1 | Unit 2 | Unit 3 |
| 1 | 0 | 0 | 0 |
| 2 | 4.3 | 4.3 | 4.3 |
| 3 | 4.5 | 7.7 (R24 on this unit is labeled 4k7 but reading 3k6) | 3.8 |
| 4 | 8.2 | 7.7 | 8.2 |
| 5 | 8.8 | 8.8 | 8.8 |
| 6 | 4.3 | 4.3 | 4.3 |
| 7 | 4.1 | 8.6 | 0.143 |
| 8 | 4.2 | 8.6 | 0.143 |
| IC4 | Unit 1 | Unit 2 | Unit 3 |
| 1 | 8.8 | 8.8 | 8.8 |
| 3 | 0 | 0 | 0 |
| 4 | 4.3 | 4.3 | 4.3 |
| 5 | 0.170 | 0.096 | 0.158 |
| 6 | 8.6 | 8.3 | 8.6 |
| 7 | 3 | 3.9 | 3 |
| 8 | 8.2 | 7.7 | 8.2 |
| Clock Frequency* | 60hz | 30hz | 45hz |
