Got it . Thank you.. That's what I did. For me, DEFINITELY, a circuit needing much more focus on dialing in the trimmers to getting it to sound right. Tweaking the trimmers ever (EVER!) so slightly will change the sound a bit so I'd go back several times adjusting the trimmers. Mine works ..... but like others have said the tone control section has minimal effect on the pedal (tho they do work just subtlety). Even tried a few other postings of trimmer voltages just (i guess) not hitting my higher expectations of what I thought it should or would sound like. I know it's not a high gain monster and it doesn't sound shitty but like I said my expectations were probably too high. Some time I'll try and go back to it see if I can coax more out of it or maybe I'll come across some voltages that get it where I'd like it. Time will tell.
Thanks for taking your time to read and reply really appreciate it only wish I had more knowledge so I could do the same .
take care and ....let's build on.
(got 3 more to do and can't wait for the byzantium since I tried 3 or 4 other flanger builds with no luck ,most likely errors on my side)
