Fuzzonaut
My first FV-1 build --- and when turned on, I get the clean signal but no wet signal at all. What I can say so far:
- bypass, pilot light, Volume knob, Mix knob all work. I get signal on pin 1 of the FV1, but nothing on pin 28.
- I have 3.3V on: pins 6 and 8 of the FV1, on pin 8 of IC2 (Eeprom), on lug 3 of the 3 Control knobs and on the inner pin of the rotary.
- Connecting the 3.3V end of R5 to ground should get me the internal FV1 programms, as I understand it, but it doesn't.
- I did a continuity check on all 28 pins of the FV1, and they connect to "the outside".
- FV1 is from @fig, PCB and IC2 from here. IC6, crystal and 1N914 from Tayda.
Here are a few pics, it's still in the box ... anything else I could check before I take it out? I have an audio probe and a DMM.
Thanks.
Thanks.
	 but ok then.
 but ok then.
