The build doc is up. The 2 b1m are for bass and treble, volume a100k, gain a1m. Also yes, 9v for each j201. I started at 9 on all and then did minor tweaks by ear. Have fun playing this pedal, it's fantastic.Ok. So I just finished putting everything together and there’s some things I’m unsure about since there’s no documentation available.
I assume the trimpots are for biasing the J201 transistors? Since there’s a TC1044 in the circuit, I take it that VDD=18V and the bias voltage for the transistors will be around (VDD/2)=9V. Is that assumption correct?
Also if anyone who has built this pedal has info on what control each pot on the board corresponds to, that would be great. Having that is a lot better than me having to turn pots and guess.
If anyone has a schematic and/or layout of this circuit and pcb that would be great too. Thank you!
Is there a recommended gain and volume setting at which we bias the transistors?The build doc is up. The 2 b1m are for bass and treble, volume a100k, gain a1m. Also yes, 9v for each j201. I started at 9 on all and then did minor tweaks by ear. Have fun playing this pedal, it's fantastic.
Using a multimeter you bias the jfets to 9v each. From there you may be able to tweak a little bit too get a touch more volume, but I wasn't able to achieve much more drive.Is there a recommended gain and volume setting at which we bias the transistors?
