Ok. So I just finished putting everything together and there’s some things I’m unsure about since there’s no documentation available.
I assume the trimpots are for biasing the J201 transistors? Since there’s a TC1044 in the circuit, I take it that VDD=18V and the bias voltage for the transistors will be around (VDD/2)=9V. Is that assumption correct?
Also if anyone who has built this pedal has info on what control each pot on the board corresponds to, that would be great. Having that is a lot better than me having to turn pots and guess.
If anyone has a schematic and/or layout of this circuit and pcb that would be great too. Thank you!
