Ashly SC-40 Clone
Amazing work! I've been working on a dual SC-40 pedal, how are you managing the 9v to 15v step? I was originally looking at using an 18v supply and a regulator down to 15v, are you using a voltage doubling circuit here? Is that the part labelled PS2 (power supply?) on your board?
Looks kinda like a Recom R09P15D
Those are cool bits of kit. I've wondered how quiet they are
Let me correct myself, upon looking closer, I think it's actually the TEC 3-0913, not the 3-1213. Think I'll pick some up for builds I'm working on, just need to figure out if anything special needs to be done when wiring it in.
I used a Traco 2-0923.
If you don't mind me asking, how is the noise levels with these, and what filtering did you use around the module? I know Aion FX uses a 2-0923 in the Eclipse Boost (schematic seen in the documentation here: link), did you set up the filtering around it in a similar way? Love to see the old Ashly gear get some appreciation, I have 2 SC-40s I use for recording along with SC-50s, and want to build myself a dual pre in a stomp box so I don't have to lug the old units to shows.
I used a similar filtering like aion. The noise level is really low, no high pitch like with the 1054 - charge pumps.
I use also a SC-40 and a SC-50. I cloned the SC-50 too...
Great, that's very helpful info! I've been meaning to get around to making these for a while, but had some other projects on the docket first, namely an Acoustic 360+ preamp in a rack (on pause until I can source a good unit with the faceplate done how I'd like). I think I'll do the SC-50 as well, did you do the blue or black version? The original I have on hand at the moment is the earlier blue version with matched metal can transistors, but was looking into making a circuit where it's swappable between those and the black version's dbx chip, though I currently only have the early version schematic.
@disssa out of curiosity, do you happen to know the current draw of your SC-40 build? In planning to build a dual version, I'm looking at the Traco power converters, the 2-0923 outputs 67mA, but wondering how much of that the circuit uses if I need to go with a version like the TMR 4 that produces 133mA in order to supply both circuits from one supply, or if the TEC 3 models at 100mA will be sufficient. Thankss!
The current draw is 120mA.
I would use a TEC 3 because the range of the input voltage is better (4.5V...13.2V). The input voltage of the TMR is 9...18V. Most power supplies deliver just under 9 volts. The Tracos react very sensitively to undersupply.
That's 67mA per rail, so 134mA total for the TEC 2. If current draw of one circuit is 120mA, even the TEC 3 won't work because it's limited to 200mA total.
Edit: Had a quick looksie and TMR 6-0523 will provide more than enough current (200mA per rail). Input voltage is 4.5-9V, so some form of overvoltage protection or voltage regulation on the input would be advisable. Or just use a 12V power supply and go with the TMR 4. Not quite as pricey as the TMR 6 either.
Excellent, thank you! Good to know about their sensitivity as well.
That's what I was thinking, if it was under 100 mA I could get away with the TEC 3. Looked at the TMR 6 too, but I think the TMR 4 will work well as my solution.
I did also see this as a possible option: https://www.cdiweb.com/products/detail/mcwi0512d15-minmax-technology/521452/
If I'm reading the datasheet right, 4.5-18v input, 167mA per rail, same pin out as the Traco devices and cheaper. Unfortunately I can't find them in stock anywhere...
Hello Disssa, amazing job once again. I am designing my PCB as well. I have one small question . When it comes to the MID Tune pot, which lugs are connected ? The schematic does not really specify. is it 1&2, 4&5 or 2&3 , 5&6 ? I have a gut feeling it's 1&2, 4&5.
Thanks in advance !
@disssa - the last picture in your first post shows the "innie" DC jack soldered to wires, which are in turn soldered to the PCB. I'm guessing you had to un-solder something and re-solder during final assembly?
Great looking build and PCB!
