Ronnie Hotdogs
Hi all
I’m finishing up my first build, as I’m from NZ I had to do the Awful Waffle.
I’ve just done a quick test and found while I’m getting audio with it off, once I switch it on there’s nothing.
Power is fine, so I did a quick work through with a multimeter and think I’ve found the issue at the op amp.
If I’m reading the schematic properly (and please bear with me as I’m still learning a lot of this) the signal exits through pin 6 toward the 10k resistor at R8 - and this is where I seem to have a break, as in these are the only components in the chain where there seems to be no activity.
Everything up to, and then after that point appears to be flowing.
What I’m wondering is whether I just swap the op amp out, or is there a specific issue I might be able to sort given it only appears to be one leg of the op amp.
Or is everything I’ve surmised absolutely incorrect
Cheers!
Cheers!
