Hey gang -- I've reached the limit of my troubleshooting skill and thought I'd toss some pictures out in case something catches someone's eye.
When turned on the LED comes on, but the pedal passes no signal. There is no noise of any sort. It's as if the guitar is not even plugged in. When the pedal is switched off but the volume and gain are turned to max you get some noise. No part of the guitar signal is recognizable in the noise (it doesn't change when you strum) so it is just the hiss of noise. And you only hear it at the last maybe 15% of knob travel. But within that travel you can just discern volume changing volume as it should, gain changing gain, and tone changing tone. The LED goes on and off when it should.
Guitar cables have been checked. I tested all of the off board jacks back to the board, polarity of the LED, power jack polarity, correct direction of caps and the diode, etc. The ugly solder with a bit of a void in it is from a 100k resistor that kept reading around 63k that I replaced. It must have had an alternate circuit path available since it read 100k back on the bench. Behavior is the same before and after that replacement.
This is the first pedal I've built without one of the foot switch breakout boards. But I've double checked those connections a couple times. The TL071CP is a temporary placeholder while I wait for LM741s to arrive.
Anyway, give a shout with any advice or if you see anything suspicious.
Thanks!
Thanks!
