Guardians of the analog
Papi Fuego
Ok, I know this is a well documented issue. I looked up troubleshooting threads going back to 2019 about this one. Some people have built multiple boards with the same issues, any time it's been brought up the issue hasn't been resolved. @Robert is it possible it's a board/layout issue with some kind of bleed thru?
Yes, all my ICs, are from a reputable source. I have checked all solder joints, checked continuity, audio probed, triple checked values and checked all wiring. I even removed the feedback switch, rechecked continuity, hardwired, rewired the switch and it's still an issue. The pedal functions with it's intended purpose, the distortion works, even the feedback switch functions like it should. The rhythmic background noise is the issue. The video demonstrates the noise and how everything functions despite the noise.
Has anyone built one without the noise? Has anyone had one with this issue that found a solution? I have not seen many build reports and Chuck's build is the only one I've seen that does not mention it.
