Out of curiosity, I quickly put dod250 on breadboard and tested various diodes. In the "250", the diodes are after the opamp, in the hard clipping configuration (two parallel diodes to GND). Two test scenarios:
- generator (500Hz 250mVpp) and oscilloscope for screenshots,
- guitar (straight into audio interface + speaker cab IR) for sound files.
Diodes in the following order: AAP153 (germanium), BAT46, BAT41, BAT42, BAT85, GAZ17 (germanium), 1N4148 (note much higher signal level, hence the scale change from 100mV to 200mV per division).
Set 1 - gain set so that there is no flattening of the sine wave peaks.
Set 2 - maximum gain.
