SOLVED Bayonet Fuzz issue
VanWhy
Just throwing it out there to get another set(s) of eyes in it. I just boxed this up and not getting any signal to pass thru at all. Which usually means input/output jack issue. I can't see anything glaring so at least if someone can just take a look and see if anything pops out. Or if anything else I should check. Thanks.
The wire is on the wrong lug of the output jack.
The signal wire should be on the bottom lug.
Duh. Thanks @Robert that Was wired wrong! I fixed that now signal passes thru. Unfortunately I get no sound from the pedal :( I'm going to mark this one as solved then go back to the drawing. If I need to make another thread I will. Thanks again @Robert for taking the time to check it.
