definitely not an expert here and i'm planning to do wire up a dual pedal with order switch.
anybody's 2cents about whether there is an ideal grounding setup for dual/switched pedals to prevent a ground loop?
thought i'd ask before embarking on a lot of trial-and-error
it's not clear from the switch diagram, but it seems like this (attached) would work with the minimum length of wire..
magenta = bridge between in/out grounds on each board, to I/O jacks
green (chartreuse?) = bridge between I/O jacks
will this work? is the green wire necessary (or worse, does it INTRODUCE a loop...)? thanks, y'all
