My Filigree Siberian Hamster's LEDs light up great, too bad I didn't put them on the outside of the pedal.
Eric, there are many factors that determine how much bass is perceived to get through a circuit. Remember I mentioned the 1n input cap for Orman's Booster and it sounds fine on bass.
If a circuit has a huge input cap and let lots of bass into the circuit, that doesn't mean the bass doesn't get killed elsewhere further downstream 10uF is 100 x bigger than 100nF (100nF=0.1uF). I think I've got my math right this time.
I can't think of a specific example at the moment, but some circuits will have seemingly good bass response, looking at the caps in the signal path, let's say 1uF, Fet followed by 1uF an op-amp and then suddenly there's a bottleneck of 47nF...
If you enlarge that 47nF to 1uF so it's like all the other caps in the signal path you might just send your sound into mudsville, or get unwanted harsh distortion (let's say it's NOT a distortion pedal, but modulation). You've upset the balance of the circuit. The 47n was used to control the amount of bass the next downstream component receives so that it doesn't oversaturate it, it's a bit of circuit or a component that cannot handle too much bass.
By manipulating the bass content at various points in the circuit, we can get a desirable sound that still has plenty of bass content. If you reduce bass somewhere, you can somewhat compensate later by boosting the bass and lowering the treble and mids = perceived bassy sounding pedal. Because you've reduced the mids and treble to emphasize the bass more, you'll now have to pump up the overall volume of the entire signal. Ahh what's that you hear now? HHHHSSSSSSSSS. With all that EQ monkeying and then boosting the overall output you've just boosted the noise floor of the pedal, too.
A common tactic to keep a low noise floor in some circuits is to boost the treble big time at the beginning of the circuit, do with the signal whatever is to be done, then REDUCE the treble before letting the signal out of the circuit into the wild. This bump and reduction helps keep the noise floor down.
Back to your Bigger Muff. As I mentioned before, the huge caps would lead you to believe the Bigger Muff is going to sound great on bass, but there are choke points for bass throughout the middle of the circuit. So just having huge in/out caps isn't going to give you bass. For a fun experiment, with the stock Bigger Muff circuit, swap out JUST the input and output 10u caps for the Green Russian's 100n. I bet it sounds like an icepick through the forehead. Those huge in/out caps are needed just to keep the pedal out of the dog zone.
Have you tried any of the mods I suggested on your Bigger Muff?
Especially those puny 47p caps. OUCH! For the love of Bass, Parallel some 470p on to the 47p!
However, that may have been what the designer of the pedal was going for, a certain flavour or texture of sound.
Another possibility is Mike Matthews got a deal on 10uF caps (or 47p) and had to figure out a way to use them up. Tweak the circuit until it's acceptable with the available components and then send it out to market...
