Chuck so far so good no leaks. But you've got me worried now... I'll use a fresh gasket next time I open it up. It's more letting the smoke out I'm worried about.
Hey phi1 - You got me thinking more about C5... So I did some more experimenting, wondering if there was a compromise which would suit both situations and I think there is. Changing C5 just a little bit makes a huge difference to how the pedal sounds. From what I've been told it seems that the bigger C5 is, the more the low end creeps into the midrange in that crucial area around 7-800Hz. Well I don't know where am I am frequency-wise but I had found 100nF to be too much for the Gretsch and 47nF too little for the Les Paul (although it did sound pretty good). But it seems that 82nF for C5 works beautifully with both guitars. In fact I think it sounds best of all the options I tried. So here is an updated schematic if anyone is interested - It may not work as well with your rig but it sounds great with mine.
It also cleans up surprisingly well with the Gretsch's volume control (which has a treble bleed on it).
