I don't see anywhere that this has been discussed, so... on the Blue Breaker silkscreen, the values for R8 and R10 are reversed. R8 is a 1K , but is shown as a 1M. And R10 is a 1M and is shown as a 1K.
I don't see anywhere that this has been discussed, so... on the Blue Breaker silkscreen, the values for R8 and R10 are reversed. R8 is a 1K , but is shown as a 1M. And R10 is a 1M and is shown as a 1K. View attachment 75870
1k off pad-3 of the TONE B25K and 1M off the 100n to output.
So the RefDes pic of the board in the build doc has mixed up the labelling of R10 and R8 as you've noted, but the traces on the PCB match the schematic and are correct and the pedal will work.
I should have clarified that the 'picture' of the silkscreen had the parts switched. My bad. I had already populated the board and could not see the actual silkscreen without lifting components.
