Yeah, they are different, the ones that I purchased from AmplifiedParts and SmallBear differ from Tayda's in shape and size. American also look better and cost moreTayda lists theirs as 20mm, Smallbear lists theirs as 19mm.
19mm would fit, although I'm not sure if there's just some tolerance in the measurements or they actually do make two different knobs that have a difference in diameter of 1mm...
You want MXR style No Skirt:Hello everyone,
I just finished my Blue Shoe and it works/sounds fantastic!
I am not so good with the assembly phase, especially drilling the holes.
Please, do you have any suggestions to fix/avoid such issues/mistakes like the following? The knobs are touching, jamming into each other
View attachment 62279View attachment 62280View attachment 62282View attachment 62283
AKA Tite Chug CityI'm not a fan of larger-diameter (19mm or larger) knobs on a 125B (unless it's a single knob-job like the XC Phase or Clandestine) so I basically keep to Davies 1900 clones or the skinny aluminum knobs, each of which run more like 12mm in diameter. View attachment 62290 Here's an example on a 2 in 1 build, which consisted of two 125B size boards side-by-side in one enclosure.
Mike
The only thing with those is that they are very short and look funny if you don’t lower the pot a bit.You want MXR style No Skirt:
"Mini" MXR Style Knob - No Skirt (15mm OD)
Tiny, yet mighty! At 15mm diameter, these small fluted knobs feature an interior brass cup, adding heft and sturdiness. For ¼” smooth shaft pots.lovemyswitches.com
US Letter (ANSI): 8.5 inch by 11 inch (width x height).I am from Brazil and here we use to use A4 paper sheets. I do not know which paper size the PedalPCB build documentation is done.
