GitHub - reghartner/bommer: Merge common guitar pedal BOMs
Merge common guitar pedal BOMs. Contribute to reghartner/bommer development by creating an account on GitHub.
This code needs clean up and refactoring...I know it can be prettier and should have tests, but it works right now, and will be of use to you folks.
Basically…
- combines BOM pdfs into a master BOM - useful on its own if you don't use Tayda
- Maps the output to a known set of Tayda skus which can be directly input into the Tayda Quick Order form.
I have tested this with a set of ~50 BOMs
Here's sample output
bommer % node bommer.js ./pdfs
Processed file BellumMKII-PedalPCB.pdf - Detected BOM Type: Parts List, Parts Found: 49, Unique Items: 26
Processed file Long-Tom-build-doc.pdf - Detected BOM Type: Shopping List, Parts Found: 34, Unique Items: 28
=== Final Consolidated BOM ===
│ (index) │ type │ value │ quantity │
│ 0 │ 'ceramic' │ '100p' │ 1 │
│ 1 │ 'ceramic' │ '470p' │ 2 │
│ 2 │ 'ceramic' │ '680p' │ 1 │
│ 3 │ 'diode' │ '1N34A' │ 2 │
│ 4 │ 'diode' │ '1N5817' │ 2 │
│ 5 │ 'electrolytic' │ '100u' │ 2 │
│ 6 │ 'electrolytic' │ '10u' │ 1 │
│ 7 │ 'electrolytic' │ '1u' │ 1 │
│ 8 │ 'electrolytic' │ '3.3u' │ 1 │
│ 9 │ 'electrolytic' │ '4.7u' │ 2 │
│ 10 │ 'film' │ '100n' │ 8 │
│ 11 │ 'film' │ '10n' │ 1 │
│ 12 │ 'film' │ '1n' │ 1 │
│ 13 │ 'film' │ '2.2n' │ 1 │
│ 14 │ 'film' │ '22n' │ 1 │
│ 15 │ 'film' │ '47n' │ 1 │
│ 16 │ 'film' │ '6.8n' │ 1 │
│ 17 │ 'ic' │ 'TL071' │ 1 │
│ 18 │ 'potentiometer' │ 'A100K' │ 2 │
│ 19 │ 'potentiometer' │ 'B100K' │ 3 │
│ 20 │ 'potentiometer' │ 'B1K' │ 1 │
│ 21 │ 'potentiometer' │ 'B50K' │ 1 │
│ 22 │ 'resistor' │ '1.5K' │ 2 │
│ 23 │ 'resistor' │ '100K' │ 7 │
│ 24 │ 'resistor' │ '100R' │ 1 │
│ 25 │ 'resistor' │ '10K' │ 2 │
│ 26 │ 'resistor' │ '15K' │ 3 │
│ 27 │ 'resistor' │ '1K' │ 3 │
│ 28 │ 'resistor' │ '1M' │ 3 │
│ 29 │ 'resistor' │ '2.2K' │ 2 │
│ 30 │ 'resistor' │ '33K' │ 1 │
│ 31 │ 'resistor' │ '390R' │ 2 │
│ 32 │ 'resistor' │ '4.7K' │ 2 │
│ 33 │ 'resistor' │ '430K' │ 1 │
│ 34 │ 'resistor' │ '43K' │ 1 │
│ 35 │ 'resistor' │ '470K' │ 3 │
│ 36 │ 'resistor' │ '47R' │ 1 │
│ 37 │ 'resistor' │ '560R' │ 1 │
│ 38 │ 'resistor' │ '6.8K' │ 1 │
│ 39 │ 'resistor' │ '8.2K' │ 2 │
│ 40 │ 'resistor' │ '820R' │ 1 │
│ 41 │ 'switch' │ 'SPDT' │ 1 │
│ 42 │ 'switch' │ 'SPST' │ 1 │
│ 43 │ 'transistor' │ '2N5088' │ 4 │
│ 44 │ 'transistor' │ '2N5457' │ 1 │
=== Tayda Quick Order ===
A-4170,10
A-968,10
A-541,10
A-159,2
A-4538,2
A-4554,1
A-4505,1
A-4524,1
A-4555,2
A-564,8
A-559,1
A-557,1
A-558,1
A-560,1
A-563,1
A-421,1
A-1135,1
A-5521,2
A-5519,3
A-5409,1
A-5524,1
A-2202,10
A-2248,10
A-2245,10
A-2203,10
A-2182,10
A-2200,10
A-2277,10
A-2341,10
A-2290,10
A-2315,10
A-2310,10
A-2779,10
A-2774,10
A-2180,10
A-2190,10
A-2282,10
A-2328,10
A-2337,10
A-2323,10
A-095,4
A-6779,1
=== Parts still to order manually ===
│ 0 │ 'diode' │ '1N34A' │ 2 │
│ 1 │ 'switch' │ 'SPDT' │ 1 │
│ 2 │ 'switch' │ 'SPST' │ 1 │
